I have a Ramco 50 ton press. I like it because it's compact, powerful, and has a ton gauge. It is old, and the hydraulics leak a little but I haven't torn into them yet.
The end of the ram was drilled and fitted with a slug of mild steel. I think the idea was to let that 'ram pad' take the squish, leaving the ram in good shape. I took the set screw loose and discovered the pad was stuck inside. The bore on the end of the ram had distorted somewhat, pinching the stub end that stuck up into the recess in the ram end.
How do you make one of these ram pads so that the ram truly stays undistorted?
The existing pad is a cylindrical piece turned down at one end to a stub which goes into the ram.
metalmagpie
metalmagpie
