It's been a while since I posted but want to thank all for the input regarding ideas of mounting my new lathe.
I recently bought a PM1228 and needed to build a stand. The lathe was going to be set up on the second floor of my garage which made the "foundation" somewhat susceptible to shifts over time and temperature. I looked at davidpbest torsion beam design and based my design on it. Apparently, this technique is used to mount lathes in ships where everything moves and shifts. I used two heavy 7"x2" C-channels welded together to form a 7x4 tube. As per david's design, I put an angle on either end of the beam with threaded adjusters on each end of the angles to act as levelers and bolts to lock it in place. I built a simple frame out of 2" square tubing 0.125" wall and put casters with built-in leveling pads so I can move the machine when/if needed but then lock it in place and level the frame. What I found was that after I leveled the frame on the uneven floor there wasn't much need to level the torsion beam. While testing a sample piece in the lathe with a DTI and looking at the twist, I found that the beam was so stiff that the twist adjusters had not effect on the beam itself. I did find that by varying the torque on the 4 mounting bolts the lathe frame would twist which meant that the beam wasn't truly flat. After a bit of shimming and torquing, the machine was solid and no twist and the lathe turned true.
Bottom line is that the torsion beam is so stiff that I doubt the 2" frame is having any effect which means that the shifting of the garage should have no effect either.
Once again, thanks for the input. I feel I ended up with a reasonably stable/stiff setup without being overly complicated or heavy.
steve
here are a few pics:
steve
