There has been discussion of tracking on belt sanders. I found a completely different version of mistracking today.
Went to use the Atlas bandsaw, and it was making an odd noise.
Picked up the part I was sawing from the "table", and found that the saw blade had decided for no discernible reason to jump forward about 10mm and start to saw the front of the table slot. It was forward partly off the wheels, out of the guides, and generally way out of position, starting to nibble on its own driveshaft. I have no idea why it did that.
I fiddled about with the guide rollers for a bit, and it went back and caused no further issues. I did nothing particularly interesting with the guides, loosened them, moved them out, then moved them back where they had been, and tightened them up again. The blade then went back where it should be, and caused no further trouble while sawing.
Very odd. I really do not like things that I cannot find a definite cause for, because I haven't a clue if I actually fixed the problem or just fixed a symptom.
No, there did not seem to be any excessive accumulations of swarf on wheels or guides rollers, or anywhere else. I had thought of that as a possible cause, but saw no such.
