The vent hole down in the tube just below the solder joint is not a bad idea at all.
I still want a way to clean away the chips once every 5 years or so. My own mental image of the tuna can style is half of a copper connector soldered to the top of the lid and then the flared inside pipe with notches slides down and is held in place with friction. I could then draw out the copper non spill tube and with some solvent swish out the junk in the can now and then.
The can would still qualify as spill resistant because it would not be on its side long enough for the oil to seep out through a typical copper pipe to copper connector sliding fit.
