Good Morning,
I am having problems with a tub/shower valve. It is at a rental property that has been rented for about 4 1/2 years.
When we bought the house the hot water ran slow from this valve. i took the valve out and ran a wire into the port where the water goes horizontally to the but filler and shower pipe. It belched out some crud and worked fine after that.
When I first found out about the slow running water I decided to change the water filter. It is a whole house filter. When I went to put the new one in I found that the tenant took the filter out and didn't put a new one back in.
I've tried running a wire into it like last time and it didn't make any difference. If I take the water valves out and turn the water on it shoots out like a fire hose so I know it is getting water to the valves. The house is ready to rent except for this one problem.
Any ideas? I'm at wits end. I have tried tapping on the valve to try to loosen up any crud but that didn't help either.
Thanks for your ideas.
