darn old plumbers...
First to the water filter:
If you have hard water, high in calcium minerals, a filter will not help. If you have particulates it can help remove them, of course.
From what reggie_obe said: "When I was living in Michigan (Lansing area) while working on a two year project, we contractors referred to the water as liquid rock. Heavy with iron and calcium."
Be careful with the acid added to the shower riser. The problem is likely much more wide spread, and acid introduced at the end of the problem won't help much. It is dangerous...
see:
also found this:
It is likely that the problem is probably mostly with the hot piping. There was a professional cleaning solution available called Borcoil, it seems that Mag-Erad may have replaced it.
The solution can be pumped thru the system to de-calcify the piping. It is pumped in from the hot pipe leading from the water heater, and then recirculated by running a hose from the hot outlets around the house back to the heater. While this will absolutely remove the mineral deposits, those deposits are often all that is keeping the piping from leaking.
While JT doesn’t like plumbers bashing great holes in the walls to replace valves, there is often no real solution other than that. Besides, as I mentioned before the root cause of the problem is not at the faucet, it's system wide...
It's tough to find a good plumber. If you can do all the system maintenance your self, that’s great. I was in the business for 42 years primarily on commercial and industrial work... and I HATED doing residential work. Kept bumping into the crap work of unprofessional, untrained 'handymen' who didn't know or care what they did. This naturally left the home owners on guard. Tough on the home owner, but in the end that's not my problem. All I can say is that I had a great and professional relationship with all my clients. Been retired 10 years next April and wouldn't trade it for anything...
In the end you have to decide how long to keep the house in an un-rentable condition before you call a professional plumber.
Hope work out the problem
Originally posted by bborr01
View Post
see:
also found this:
