I been Muckiung about with Various Machining Projects in thew Shop. one of is Deep Hiole Drilling. I am at a loss with my old Lathe since it only will Run 840 RPM wound right out. I wishj it would go faster!! Ideas? Maybe Pulley Size Increase? I wonder what a Cinncinatti Tray Top Lathe could Run at before Damage would be done to it? Anyhow I get so much great Ideas fro mthis Site and Its Members I wish to try to give some back. Check this Video very very nicely Made and it gave me more Ideas than I had before regarding the Drilling Issues I am Facing. Im doing 13.5 inch Deep by .375 Diameter. In prehardened 4140 Matwerial. It is NOT a through hole .Shafts are 28 Inches Loing. Thanx
Good Information I found Deep Hiole Drilling In home Shop
You didn't say the age, type etc. of your machine but a lot of older machines where only designed to "go slow" and cranking up the rpms on them will just destroy the bearing surfaces.The shortest distance between two points is a circle of infinite diameter.
Southwestern Ontario. Canada
I'm doing some deep holes in 17-4 SS right now. A 3/16" diam. x 4.5" deep. It was giving me a lot of grief before switching cutting fluid to Boelube. Then it started cutting smoothly. I was able to go about 1/16" deep at a time before pulling the drill to clear chips. Before that, I could only go 20 - 30 thou. at a time with chatter and binding.Kansas City area
