I recently picked up a LMS Hi-Torque minimill, in great shape- before the PO dropped it on it's back and crushed the motor control box. I bought it as-is, knowing those boards are $100. Well, turns out this one is $273! The motor is 500W brushless, rated at .67 HP.
So a little research says I can run it with a SCR and a bridge rectifier for under $20.
For that matter, a Variac and a bridge rectifier should work as well, n'est pas?.
So what am I missing?
What does the OE board do for 10 times the money this does not?
