Originally posted by mattthemuppet
View Post
the nevada triangle
Legal aliens? Really? Who issued the landing (or hovering) permit? NASA? The Russians? Fidel? Can I see a copy?
Originally posted by 3 Phase Lightbulb View PostThose are legal aliens....Paul A.
Originally posted by bborr01 View PostMost of Nevada is sparsely populated. I've been through a lot of it and aside from Vegas and Reno there isn't much there.
Having said that, I myself would not live in desert country like that unless the alternative was being flung into space without a spacesuit; but some people love it for the starkness of the nature.
Originally posted by tomato coupe View PostI hope you meant after the sea wall.
There's also Quito airport, where you get to stare into peoples living rooms if you wish as you descend, and Bogota airport, where the pilot has to remember to take a sharp left or right turn immediately after taking off or the plane hits a cliff.
Originally posted by Bill Houghton View PostThere's actually quite a bit there, just not at the scale you're probably used to. Stop, get out of the car, lie down on the ground, focus close up, and before you know it, you'll see all kinds of wildlife. If you're unlucky, you'll find you were lying on some wildlife that doesn't like you doing that.
Originally posted by Yondering View PostPretty sure he meant there's not much population there. Of the human kind that results in lots of air traffic. But you probably knew that too...CNC machines only go through the motions.
Having personally been a passenger several times while flying over the Sierra Nevada mountain range two things were left indelibly carved into my memory.
One was the sheer beauty and size of this majestic mountain range. The other was the incredibly powerful and unpredictable winds that toy with relatively low flying planes that frequently cross these mountains. Due to the proximity of the large population base of central California there are a very large number of flights traveling directly into the gauntlet of the Sierras so it stands to reason that there will be an unusually high number of incidents.
An explanation below that I feel accounts for a lot of the mystery if not all.
You’ve likely heard of the Bermuda Triangle, an area in the Atlantic off the coast of Florida where planes and ships have mysteriously disappeared for…
Professor Kelly Redmond, a climatologist with the Desert Research Institute in Reno, has looked at wind formations in those mountains seeking answers.
Redmond told KNPR's State of Nevada that much of the problem in the Sierra Nevada is because of the wind.
The mountain range runs almost perpendicular to the Jet Stream, that along with their shape, which is wedge like, creates wild wind conditions.
"So, when the winds are coming up, they come up kind of smoothly on the west side and then they have this very rapid decent and there is a tremendous amount of turbulence that can be caused by such situations," Redmond said.
He said when a small plane, which must fly lower than commercial jets and doesn't have enough power, gets caught in that air flow it can be difficult to get out.
"It's quite easy for a small plane to get caught in the down draft on the downwind side and not have the power or just the capability to get out of the way of that," Redmond said.
Bad Decisions Make Good Stories
The lee side of a mountain can have sort of a 'compression spring' effect on the down draft when strong winds are blowing normal to the ridge axis, propelling strong turbulence for quite some distance downstream.
I taught the weather course for the AF pilot training program, and we had a training film showing a B-52 that had much of its vertical tail/stabilizer torn off during Extreme turbulence east of the Rockies in Colorado. They landed it safely in Kansas (as I recall), after much consultation with Boeing engineers and various flight safety groups. I don't recall the altitude they were flying, but probably well above the height of the mountains.Lynn (Huntsville, AL)
