Started to sharpen and use a Stanley 60 1/2 low angle block plane.
could get a mirror finish and shave my arm with it but it wouldn't plane wood except taking tiny strips off a corner.
I use three Record planes and can get them sharp enough to shave off end grain of oak or walnut, so i know what I should expect. Being low angle it should work better on end grain.
Kept sharpening, testing and inspecting and concluded that the blade is simply soft. Has the Stanley name engraved on the iron and this one takes
a blade with several slots machined in the back for the adjuster to engage in so its a factory part I'm sure and its looks old.
I would expect it to chip if too brittle or fold over if too soft or simply dull but this looks like the wood has hammered it to dullness and it does it instantly.
Its interesting to learn that when sharpening with the right product and procedure that one can look into the edge and see nothing. Any dullness shows as a line, an end where there should be nothing. Once knowing what to look for its easy to see.
Suppose I could treat it like oil hardening steel?
