Hi,
I am considering making a pipe roller and I'm planning on having the three roller setup with the middle moving up and down on a screw and the bottom two being driven either by gears or chain and sprockets from a 3 phase motor with a 100:1 right angle worm gearbox so should be around 14rpm. Is this two fast or slow in your opinion.
I have a few other decisions to make. What would be better for the driven wheels? Larger diameter or smaller? I would assume the larger the better as there will be more surface area in contact with the pipe so it will less likely slip? Does the diameter really matter for the middle moving die?
Also I'm thinking of engineering plastics for the dies?! Is this wise? I know they are very good under compression loads?! Or should I stick to steel?
Thank you in advance!
Dave!
Dave!
