As some people are doubtless aware, ive made a long-term project out of making improvements to my Grizzly G8688 mini-lathe:
http://bbs.homeshopmachinist.net/thr...s-A-WIP-Thread
As a companion to that tool, ive also got a Grizzly G8689 mini-mill, and i figured "hey, if im spending this time working on the lathe, why not put some effort to the mill as well?". Much like the lathe, the mill is a tool that worked plenty well straight from the tent sale i bought it at. It spun bits, it drilled holes, it made parts, it worked about as youd expect; passably, and thats all you can expect for something you grabbed off a pallet for $100. Not great, but workable.
Being honest, the only reason im touching either of these machines is A) im a firm believer that your work will never be more accurate than the tools you use to produce said work, so it pays to make sure the tools are as accurate as you need them to be, and B) im bored. I have also found some problems with the machine that are affecting the desired accuracy of my work, and those are what ill eventually be addressing.
As it is now, the tool has already had a few mods made to it. The head has been fitted with a gas spring and a belt drive conversion kit, and it has been fitted with a DRO courtesy of a few igauging absolute digital scales and a TouchDRO controller. Planned improvements to the mill are as follows:
-Replace the head bearings with a set of angular contact or tapered roller bearings. As with the mini lathe, i feel that this will improve the machine where the rubber meets the road, at the spindle
- Replace the base and column with a fixed-angle version. My mill is one of the tilting column types, and theres an unfortunate lack of rigidity to it. The solid column conversion kit that LMS offers is a very desirable upgrade to me
-Check and overhaul general alignment. One of the biggest problems ive noticed with my mill is that the table does not seem to be parallel to the direction of movement, which makes for wedge-shaped parts and problems tramming the mill
-Improve fitment of sliding surfaces. Id like to find a way to make the bearing surfaces on the ways just a touch better, be it through scraping or surface grinding.
Thats all that springs to mind at the moment, so off to the races!
