Behemoth of a dovetail cutter finally showed up, so im back to work on the saddle. Quick refresher for anybody who doesnt feel like reading through, im presently finish machining a replacement saddle assemble to correct the X and Y axes not moving square to each other. Ive already got the outside bits surface ground flat to use as reference surfaces, now im machining the 55 degree dovetails.
Now, in this next part im going to be explaining how and why im cutting these dovetails and what im focusing on. I realize that a lot of people already know how to cut a dovetail, if you do feel free to skip this part. This is more for Joe Newbie who stumbles across this thread. Now, some visual aids:
Some color-coded photos of the saddle, both as its own thing and installed on a mill. Itll make explaining easier for me. Now, first face we want to look at is the black face, what im going to call one of the working faces. This face is going to be what makes direct contact with the dovetails on the base of the mill and underside of the table. These faces, on top and bottom, need to be parallel to each other, otherwise the face of the table wont be parallel to the travel of said table. Flatness and parallelism of these faces has already been taken care of at the surface grinder, and theyve been ground as flat and parallel as i can measure in my shop.
The red and green faces make up the portion of the dovetail that ill be milling in this setup, and can be referred to as the actual dovetail. In this instance, the red face is a working face, it makes direct contact with a mating face on the table or base, depending on which side of the saddle youre looking on. This red face needs to be parallel with the other half of the dovetail making up one axis, and perpendicular to the dovetails on the opposite side of the saddle. The green face is clearance in this application, it has no real bearing on anything.
Now, to re-cut the dovetails ive got the saddle clamped in my milling vise, with the ground faces of the dovetail trammed in to be perfectly parallel to the table, and the vise trammed in the X direction. In order to get the new saddle square on a mill that doesnt presently move square, im not going to make any cuts along the Y axis, instead im going to rotate the vise and attempt to transfer the accuracy of the vise onto the part. Now, the first setup:
Ground face up against the fixed jaw, long edge of the vise trammed along the X axis. The cutter ill be using:
Thats a 50mm 55 degree dovetail cutter. Yes, the angle is bolded for a reason. The dovetails on these machines are 55 degrees and require a non-standard cutter, as i found out to my detriment. Bit of a pain to find, only ones i could find were cheap imports, and yes, thats the bad cheap. This one is HSS, ran me about $30, and has an annoying amount of runout. Still, the angles proper and it cut well enough. Its being held in a 5/8" er32 collet, which is interesting for me because my mill doesnt like the stickout that collet game me. At least, my mill didnt used to like it, after upgrading the column, 0 problems. Money well spent im feeling. Anyways, lets move on to the part:
Thats a closeup of the dovetail as i got it. It doesnt show up quite as bad in a photo so youll have to take my word for it, the surface was pretty rough and franky didnt feel flat at all. Color the surfaces of the dovetail with a sharpie and take a quick pass to see what gets cut:
Surprising nobody, its not flat. I wont bore you with the step by step on how to cut a dovetail, ill just skip to the end where i got the entire surface remachined and looking good:
Actually got a bit of reflection going on the machined surfaces, i was pretty happy with that. Thats one half of the dovetail done, now im going to step over and cut the other side to be parallel to the first, and just as smooth, before breaking down the setup to work on the other side
