I deided to just make a thread of this instead of disjointed posts in "what did you do today".
I started re-scraping a portable slideway I have, so it can actually be used. Fits were crummy, it blued like a piece of the Ozarks, and it clearly had worn at one point to where the slide was riding on a surface not intended to ride on. That had been repaired partly by planing down the dovetail on the base that it was riding on. Apparently the other way surfaces were either ignored or just milled and called good.
Toolholder t-slot surface (on crosslide), after some scraping... it blued in two corners originally. Gonna take some more work.
Cross-slide surface of the "carriage". Early, about one scraping pass. Nice visible "as-milled" surface for the slide to move on.....
The shiny spots it was, but is not supposed to be, riding on. The flats to the side are where it should ride.
Decoration apparently applied as compensation for the crummy slideways... ?????
It was on the top of the crosslide also, and pretty deep.
