I posted here back in the summer about picking up an Atlas 7 shaper. Well it ended up being an early model (1939). So I started searching around to learn all I could about the early shapers and there wasn't much out there. So I have decided to gather as much info as I can about them. I have started a serial number database. I have 8 examples so far. If you have an early shaper would you please help me out and let me know so I can add yours to the growing list. Thanks in advance.
Early Atlas shaper database
"Atlas" and "Shaper"
That's a no-no and not a go-go.
https://www.practicalmachinist.com/v...elines-137724/
Just so you know, many thousands of Atlas shapers helped in production shops around our nation during WWII and after. These are above "home shop grade".
Dan LSalem, Oregon
This may not be of help, but my Atlas 7 is pretty old. Bought it 50 years ago used. It has the table support leg. The only identification on it is two round aluminum "Atlas" tags , one on the ram and the other on the bull gear cover. No other tags. There is the number "629" stamped on the face of the top of the left hand vertical way. I assume that this is the serial number. Mine might be one of the very first to have the support leg ?
Oh' and the paint is a dark gray, if I remember the later Atlas machines used a light gray, "machine gray" color.
Joe.
Joe.[/QUOTE]
I had a 10F lathe with the pick-o-matic gear box atattchment. I believe the POM was offered from 1937 to sometime after WW2. Both the lathe and the POM had factory paint, but the lathe was light gray, and the pick-o-matic and the gear cover bere painted the darker gray. Both were original paint colors, it was the same under the badges. I repainted this lathe when I rescued it from the dead about 35 years ago.I cut it off twice; it's still too short
Oregon, USA
Originally posted by Tim Clarke View PostI don't think mine is a early one, but I have no way of knowing. It is tagged as a 7b, however. For what it's worth, the # is: 012020
Originally posted by JoeCB View PostThis may not be of help, but my Atlas 7 is pretty old. Bought it 50 years ago used. It has the table support leg. The only identification on it is two round aluminum "Atlas" tags , one on the ram and the other on the bull gear cover. No other tags. There is the number "629" stamped on the face of the top of the left hand vertical way. I assume that this is the serial number. Mine might be one of the very first to have the support leg ?
Joe.
