I'm trying to solve a 15A breaker puzzle and set up a test bed to check the equipment. I have a Fluke 10A digital multimeter that measures inline and an Amprobe analog clamp on. Running a heat gun I got 8.25A on the Amprobe and 10.75A on the Fluke. Who should I believe? Does the Amprobe need calibrating?
Not really relevant, but the puzzle is a tenant in a little apartment keeps blowing the 15A "screw in" retrofit breaker in her old school "glass fuse" panel of 2 branches on one 20A line. Yes, horrifying, but it's been like that the 21 years we've owned the place, it's the last one that has not gotten a new 60A riser and panel. In that 21 years there really has been no problems, modern ACs and lighting are really efficient, and most people don't do much else that draws much power. I thought maybe these weird retrofit breakers were "breaking in" and tripping at lower than rating, but my bench test showed it not tripping at 16A on the Amprobe. But if the Amprobe is reading 20% under, than that data is off.
