We got a Nebel lathe a few years ago and moved it to its final resting position a few months ago. We kinda leveled it. (read - didn't really try)
I had a project where I needed to bore a 6 inch long cylinder. Made the first cut - measured from one end to the other. WTF - .006" bigger at the chuck! The lathe is not new - see picture below. The ways look pretty good compared to the lathe we replaced it with. (turn of the century flat belt converted lathe...) This one is like a cadillac... Gear head, Quick change gear box, clutch..
Anyway - after trying to figure out what the heck was going on - Measuring and re-measuring everything.. (thinking the headstock would need to be shimmed or something... - which would not be easy because it is keyed on the ways...)
we leveled it. Took about an hour. Just to a test cut - now over 8" it is < .0005"
Level your lathes...
