I bought some 'spring sash rod' today. This is basically a flexible curtain rod, which you slightly stretch across a doorway or whatever to hang a curtain from. At any rate it's just a very long spring with a vinyl covering. Some of this stuff has an ID of just over .063, so a 1/16 diameter wire rope can be inserted through it. Makes a handy cable sheath.
My spray booth project required me to remotely operate a couple of sliding gates to open or close the vents, and this is what I used. Turns out the cable I wanted to use has an OD of .066 and is just a tad too tight. Some other cable I found measured .063 and that worked perfectly. Just for gits and shiggles I went to Rona and measured the cable they sell there- .063, so I know that will work with this sash rod.
This isn't the first time I've used this method to handle a cable actuation. It does work well and I've had no issues with it- other than the too fat cable that I tried to use. Of course I lubed the sheath and the cable as I was assembling it.
