Originally posted by RichR
View Post
Drill size calculator for tapping holes
Originally posted by PStechPaul View PostAlso remember that drills have a certain diameter tolerance, and typically may drill 0.001" undersize to 0.005" oversize, especially if not perfectly sharpened, and depending on how long it dwells in the hole, and other factors.
The recommended drill size is just a guideline. If excessive torque is needed (assuming the tap is good), then just open the hole to the next closest size up. Or perhaps use a pin gauge to determine the actual size of the drilled hole, if you need to tap to a very close tolerance of fit.http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
Major Diameter - Pitch = ~75% tap drill
Major Diameter - (Pitch x .66) = ~50% tap drill
For inch threads Pitch = 1/TPI
As Doozer said, it works for both inch and metric threads.
Major Diameter - (Pitch x DOT/75) = DOT% tap drill
where DOT = desired depth of thread expressed as percentageRegards, Marv
