3D printedParts
  • 3D printedParts
    I was looking for a thread dial for a sb lathe and these showed up, is this for real? Yea I’m a hillbilly
    -If I recall correctly, the dials for a Southbend, like those on a Sheldon and a Logan, are all part of the "lash" of the cross-slide leadscrew. That is, the dial acts kind of like a washer, that the handle/knob/wheel tightens against to reduce the amount of slop.
    I'm not sure I'd like a hunk of plastic there rather than aluminum or steel, especially if whoever printed it used a low infill (IE, it's not as solid as a single chunk of plastic) but that's just me. Generally speaking with positive-rake tooling, there's little thrust on the cross-slide screw anyway.
    If it's a matter of getting the machine up and running (IE, you don't currently HAVE a dial) then by all means give it a try. But again, if it were me, I'd only use it 'til a metal one can be located or made.
    Doc.
      Doc.
      Maybe I described it wrong.
      I mean the dial that you use when threading. It’s hooked to the main leadscrew
        Are you talking about this?
        I designed and printed this for my South Bend 9" lathe about 2 months ago, it is made from PETG and it is very tough. I used 100% infill, primed it in auto paint and painted in in the same oil based paint I used on my lathe. The rest of the parts are all machined of mild steel, I simply duplicated the factory dial on my other lathe. Actually the printed part is cleaner looking than the original by a wide margin.
        Mcruff
          I don't see any image, but if you mean the thread synchronizing dial, then a printed, plastic part should work just fine. There is little stress on it. In fact, even a plastic gear would be OK. It may even be better as it would produce less wear on the lead screw.
          I would use a piece of drill rod or actual shaft stock for the shaft.
          Paul Alciatore
            I could use some new dials for my Grizzly, good idea!
            No pics are showing up for me?
            Fedora 29_64 running the latest chrome.
            Jon
              Thanks guys, less stress is always good
                Grizzly sells the parts to make one for their modern 10k. They offered it as a kit until last summer. All steel or cast iron. Noteleactly like the old originals, but close
                Works on the old 9ABC and 10k
                About $60 shipped for everything
