BC Ames Triplex Lathe Anyone ever use one
Tags: None
I think you can probably count on the fingers of one hand the number of people, pretty much worldwide, that have used one of those.
I'd imagine the seller is probably about a third, if not a full half, of that total number.
That is an interesting looking machine, but I can't imagine it's all that common.
Doc.Doc's Machine. (Probably not what you expect.)
They where originally designed for use on ships where space is tight. I did have a friend that had one but have no idea what happened to it.
If you have access to old Model Engineer magazine there are a couple of right ups from Urwick about how and why he made his Metalmaster lathe.Last edited by loose nut; 02-03-2019, 09:14 AM.The shortest distance between two points is a circle of infinite diameter.
Southwestern Ontario. Canada
It's been ten years since @jackary posted his modern implementation of the MetalMaster and called it the Stepperhead.
I think they are pretty rare,I was shocked when I seen one on Vintage Machinery it is missing the cross slide $500 for it.The one in pic was restored by a fellow in Australia which came off a ship with the purchase price of $2200 in 1938 holy $hit that was a lot of money then.I thought the curved arm with deg. Marked on it was real ingenious and goes up to vertical postion for drilling or milling.
It cooled off overnight here -42c this morning 20 km wind,weather net says feels like -55cLast edited by Tundra Twin Track; 02-03-2019, 12:14 PM.
As pictured it was a lathe but the head stock could be rotated up into the vertical or at an angle for use as a milling machine or drill press.
The metal master was a strictly home built machine but it was made from foundry castings and was a high quality build. There wasn't any reason it couldn't have been made and sold commercially but it was a bit to unconventional to interest anyone in making them.Last edited by loose nut; 02-03-2019, 07:33 PM.The shortest distance between two points is a circle of infinite diameter.
Once saw a German version of something similar- looked very stout even though of a small size. Sure would be handy if you're angling holes into parts or milling angles for dovetails for example. Or facing angles on billet- the making of V-8 model engine blocks for example.
I wonder how big of a block you could machine on that thing? Something like 1/4 scale perhaps?I seldom do anything within the scope of logical reason and calculated cost/benefit, etc- I'm following my passion-
