I purchased an older atlas a year ago and have used it occasionally, but unfortunately haven't learned much on properly selecting tooling.
My understanding is left tooling cuts from left to right, right tooling the opposite, and neutral for...?
I'll be using my lathe to turn basic spacers, bushings, etc. So 1 OD and or ID, and bushings with a lip (like a top hat). My current issue is what tooling do I need to use for rough stock, finishing, and to create the 90 degree corner in the lip of the bushings i need to make? I will be upgrading to inserts.
