For the past week or so I have been trying to bring a badly robbed and long disused Atlas Horizontal mill back to life.
I was plagued with problems on the X axis. Initially the telescoping screws were rusted together and it took a lot of force and heat to get them to behave.
However, even after they were moving smoothly the slide would, at random tighten up, stay tight for a while then , on reversing its movement and reversing it again slacken back.
I would add that it is obvious the machine had seen a lot of use, its owner bought it for $ 35 as junk.
After a lot of dismantling, head scratching and a few wrong diagnoses I found that the turned down ends of the gib adjusting screws were smaller than the recesses drilled roughly ( Chewed, worn ,created by aliens)?? ! in the gib strips and the strips were moving slightly lengthways thus they simply could not hold adjustment the screws and one in particular climbed and fell on the recess as the slide moved.
My cure was to flat bottom the recesses in the gib strips with a slightly larger end mill and make new adjusting screws to fit .
I simply do not have the skill, time nor energy to rescrape the slides for my friend, they all get a bit slacker in the middle of their movement, however, at least Z now does noe virtually seize at random now.
I hope this will encourage and help someone, Regards David Powell.
