My friend bought a K&T horizontal boring mill that supposedly has a Cat-40 spindle but cannot find tool holders that fit. He has bought several holders, but none of them will tighten up on a tool. I have not looked at it yet so wondering if anyone here knows if K&T has some secret means of getting the tool holder to hang onto a tool, or did he get some wrong info, and maybe the spindle is 50 taper? He also said there is a compression spring in the bottom of the socket, and no draw bar. I can't go there today, so fishing for ideas on what to look for. It's been years since I last ran anything that K&T made.
K&T cat 40 tool holders
If there is no drawbar that explains why they won't tighten up. A 50 taper looks massive compared to 40, will swallow it. A BT 40 is the same taper as the Cat but with metric thread.
I think we need some measurementsin Toronto Ontario - where are you?
Originally posted by Dave C View PostMy friend bought a K&T horizontal boring mill that supposedly has a Cat-40 spindle but cannot find tool holders that fit. He has bought several holders, but none of them will tighten up on a tool. I have not looked at it yet so wondering if anyone here knows if K&T has some secret means of getting the tool holder to hang onto a tool, or did he get some wrong info, and maybe the spindle is 50 taper? He also said there is a compression spring in the bottom of the socket, and no draw bar. I can't go there today, so fishing for ideas on what to look for. It's been years since I last ran anything that K&T made.
There is no provision for a draw bar. The socket is a blind hole with a compression spring in the bottom. The more I thought about it, it would make sense that the spindle is equipped with a quick change socket, which may require compatible tool holders. I need to do some research.“I know lots of people who are educated far beyond their intelligence”
Lewis Grizzard
Originally posted by tomato coupe View PostYour post is a bit confusing. It makes it sound like your friend expects a CAT40 tool holder to "squeeze" a tool like an R8 collet.“I know lots of people who are educated far beyond their intelligence”
Lewis Grizzard
Originally posted by Dave C View PostThere is no provision for a draw bar. The socket is a blind hole with a compression spring in the bottom. The more I thought about it, it would make sense that the spindle is equipped with a quick change socket, which may require compatible tool holders. I need to do some research.Last edited by Mcgyver; 03-11-2019, 04:10 PM.in Toronto Ontario - where are you?
