Alright. I've been persuaded to start this by VPT since he said he'd enjoy reading it.
Well, the story is this. I have had belt grinder envy for a while. I want to build something decent and, having asked people's thought on it, I'm looking at a 2HP 3-phase TEFC motor with a VFD. This will probably be to Jeremy Schmidt's design but that's not set in stone. I've not ordered the motor yet as I've spend the budget on a (necessary) portaband
Currently I have the aluminium to make the wheels and the bearings....but not much else.
Apart from cash-flow, there's another tiny bump in the roadmap for this project: not enough space! In order to do this - and to maintain my sanity - I'm going to have to expand my workshop from tiny to merely small. I currently have half the room and the rest is storage - partly of tools etc but also of things like half-cans of paint and the like that could live somewhere less convenient like the loft....which is another project in itself. I should, at this point, warn that this project is likely to be glacially slow. Doing anything relies on first doing something else....which in turn relies on doing something else. You know how it goes, right?
So, my thought is to get rid of the wooden bench I have (that isn't rigid enough and also split - varnish and pressure-treated wood turn out to disagree with each other) and replace everything with one long bench made of square-section steel tubing. I've been working on a plan - for a change - so I can see if everything is likely to fit. I'd appreciate any comments on design, materials, layout...anything constructive at all. Especially about the jib-crane I've added. I've no experience here but it would be nice to be able to lift things onto and around the bench if necessary - we're not talking tons here, just the likes of the 120kg for the lathe or 70kg for the mill.
This is the plan so far (click for larger version or download the over-size Sketchup file):
SketchUp Model 23MB
- The wall at the back is drywall on a stud partition - office space behind.
- The red RSJ holds the weight of the flat roof - although there are wooden joists running at right angles. The RSJ seems to be merely sitting on the top of the medium density block piers with a splat of mortar to keep it in place - so I figure it would take load directly hanging down from it but not so much torsional load without some sort of bracing.
- The big grey/blue block on the ceiling is the current position of the ladder - it could be moved a little but the jib needs to clear this.
- All the models of the machinery are approximations - similar items stretched to about the right dimensions. The mill's table isn't that long, it's representative of the total travel. The transparent part of the lathe door is to ensure enough space to swing open the change-gear door.
- Boxes piled up under the bench are mainly tool cases.
- The floor isn't totally flat like it is in this model - it's not horrible but it's neither flat nor level by any stretch of the definition.
- I've modeled the framework of the bench to be modular - each section would bolt to the next by means of a flange. This is so it can be built in sections (in the garden) and assembled in situ and also so it won't be too heavy to handle for painting.
- At the moment I've put the belt grinder (that I want to build) at the far left with the bench grinder on a pull-out shelf below it. The theory was to at least have all the grinding down at one end and the door shouldn't hit the belt grinder's table that end. Mill and lathe could be swapped around or moved down - currently they are one section to the right.
- The wall currently has dado trunking carrying electrical outlets on the right hand half. This shouldn't be hard to extend. It also has peg boards, storage bins and the like screwed to it so this isn't wasted space like it appears.
- Once I've got a little spare space (one section of bench) it could be used to weld on for parts of the grinder build. This is assuming that it's safe to put the ground clamp on the same bench that the mill and lathe are sitting on?! Or do I need an electrically isolated section if I want to do that?
- The compressor shown in the model is a place-holder. I'd like shop air but don't currently have the room.
