Poor man's induction heater power supply question.
  • Poor man's induction heater power supply question.
    After seeing one of the techs in our shop use a "Bolt Buster" portable induction heater to heat some corroded & seized 21mm nuts to red hot in under a minute, I decided to look around & ended up getting one of these widgets:
    https://www.amazon.com/s?k=fosa+1800...ref=nb_sb_noss
    The shop threw out 2 battery chargers last week so I snatched 'em up. I haven't stripped them down yet to look at the transformers but the specs look like the available power should be in the ballpark without dropping a bundle on a commercial PS. They are identical chargers & both have dead digital control/display boards. The transformers should be identical and still good since there was no magic smoke or smell when the chargers died.
    Here's the spec label:
    I should be able to make a PS using the 2 TX's in series, a suitable rectifier & capacitor, yes? The primaries would be wired in parallel & the secondaries in series, correct? Does the whole idea seem feasible?
    You may be able to do it with those, what VA does the transformers appear to be?
    For a HF unit Google Royer HF heating unit .
    Make sure you phase them correctly.
    http://kaizerpowerelectronics.dk/gen...uction-heater/
    Max.
      It is going to work- are you planning to gut the power supplies and use them in brute force mode?
      This is interesting- if your chargers have a simple, two lead output winding from the transformers, then you can wire them in series and just use one bridge rectifier and one large output filter cap. But if they have tapped secondary windings, you could wire them in parallel, ignoring the taps, and then use the same bridge rectifier and cap.
      I like the idea of only needing one filter cap- and make it a big one, like 50,000 mf or even more. Be aware that the no-load voltage could be up around 40 volts or so- you'll want to know to make sure your capacitor has a high enough voltage rating.
      And of course you would phase the windings properly
        Does that induction heater module have a power regulation option? I guess it does not as they are quite simple on most instances. In that case you would preferably need a DC source that has smoothly variable voltage. Also you need a panel volt and ampmeter to indicate wether you are within the safe zone. Flying blind with such a setup usually ends in magical smoke, tears and sobbing
        About the dead chargers....are them switch mode devices or iron core? If they are switch mode and busted, then fixing them up can be quite a task. Also you can effectively forget about wiring them switch mode contraptions in a combined bundle to up the power. From iron core devices you can save the transformers+rectifiers+possibly caps and use these in a combined manner to create a new power supply of suitable parameters. This will also be quite a build, but when done properly shall yield a foolproof and hardy universal power supply that can be used for numerous projects.
        For practical purposes I would not strive towards pushing these induction heater modules much in excess of 1000W regarding prolonged use and high duty. Previous experience has shown that the declared wattage is grossly overrated and one can strip a third off it as starters if any reasonable service life is expected out of these.
        This means that a smps DC power supply of 24V 1200W would be very much adequate for driving the setup. There are standard units available on ebay/amazon and these run in the price range of about 50-100 bucks per piece, depending on how good a deal you can get. Also these have a pot that can be used to adjust the output voltage....not in a very wide range, but appreciably. If you value your own time in any sensible measure and also take into consideration that the power supply build will require extra parts and accessories (some of which shall be burnt in the process and will need to be replaced) then I do not think you can win much in terms of money with rebuilding the old chargers vs. acquiring new one.
        Although in the range exceeding 1000W the cost of contemporary units for generating and converting the power goes up really fast, so a DIY approach with building your own "monster power supply" seems a tempting approach. Also you could try a lower wattage supply first....say in the range of 600W capacity. Just to get to know the system and see how it behaves under load. These are usually much cheaper and you could avoid spending a lot of time trying on getting the chargers operational again.
        E.g. here is a small universal lab power supply that I assembled from contemporary affordable modules. Smoothly regulated DC 1-50V output with about 5A max continuous current. I packed together a small 12V DC smps, a 130W SEPIC converter (up and downconverter) and some panel meters to monitor the values. If I remember correctly the plastic case for the power supply cost more than the internals and these were about 30 bucks altogether. The induction heater supply could be done in roughly the same manner, but with much beefier modules of course:
          For max power on that unit I think it requires 45V 40A
          Helder Ferreira
          Setubal, Portugal
            I spotted a little traffic from here to my website, www.kaizerpowerelectronics.dk and came here to give me view on these IH.
            We have had a long discussion and sharing of experience with the 1000/1800/2500 Watt chinese induction heaters here: https://highvoltageforum.net/index.php?topic=530.0
            I made 5 videos about the 1800 Watt model and two different cheap power supplies, one made from laptop chargers and another made from server power supplies.
            Here are the 5 videos on different topics:
            1) Unboxing a Chinese 1800 Watt Induction heater: https://www.youtube.com/watch?v=E0Wxj0_slSc
            2) 2000 Watt laptop charger for induction heating: https://www.youtube.com/watch?v=5iMFYdDMfXo
            3) Chinese 1800 Watt Induction heater, 5 minute stress test: https://www.youtube.com/watch?v=jmAZhjl8Ybk
            4) 2200 Watt server power supply for induction heating: https://www.youtube.com/watch?v=xRAlXCzsY3Q
            5) Chinese 1800 Watt Induction heater, 10 minute stress test at 1500W: https://www.youtube.com/watch?v=v-TsBLFp8yo
            I hope this will help you build a cheap IH
              You are the man! Lotsa new stuff to learn. (...and you have to explain that forum name)
                Great info! I have also been interested in the IH for sometime but decided I just dont have the knowledge to make one. I may revisit that project. JR
                  Thanks for all the input guys!
                  I stripped one of the chargers down last night and wasn't expecting the XFMR to have this many windings & connections on it. The overall size & weight of the thing appeared to my untrained eye to be manly enough by itself but after watching Mads' videos, it looks like I'll need MORE POWER! I have no clue if it's possible to connect the secondary windings in series and/or remove some primary turns to get around 36 to 40V & 40 amps out of 2 of these things in series. Opinions?
                    Allright, an iron core monster! Them things are "pliable" and you can connect them in a number of ways to get the desired end result. Usually the secondaries on these are tapped in steps to get the varied output voltages needed for the charging. Also they are quite bombproof, so if you mess up the phasing it will not instantly blow out the smoke like smps style contraptions do.
                    I do not know how long you intend to operate the induction heater in one setting, but if you foresee hours worth of cooking at >1kW then honestly the transformers are going to burn up if you do not immerse them in a massive oil bath. If we are talking mere minutes of operation at a time then you can get away with it. Most of the heating shall occur in the transformer core that is confined and since it is massive, will not cool effectively even under forced ventilation. The modern rectifiers are not really a problem in terms of heat dissipation.
                    You can connect these transformers in a number of ways and feed them to a common rectifier and cap bank e.g. :
                    Note: several smaller electrolytic capacitors in parallel are performing better than one huge specimen (the cap internal resistances become paralleled and are thus in sum reduced)
                    From the cap bank you can try to directly feed the induction heater, but if you are not able to get desired voltage from the combination of windings then you can include a stepup or stepdown converter after the cap bank to deliver adjustable voltage. But that converter has to be a beefy one to withstand the currents.
                    Something of the following sort, but preferably more powerful:
                    https://www.ebay.com/itm/1500W-50A-D...frcectupt=true
                      The size of that transformer looks about right for the continuous specification of 12V at 20 amps, or 240 watts. So you would need eight of them to get the 1800 watts for the induction heater. Also, the welded laminations will make the transformer saturate and essentially limit the output current (which is fine for a battery charger), but not for a fairly "stiff" voltage source.
                      You might do better to use a couple 12V batteries with the chargers working as such and connected in series. You should be able to draw 75 amps for 5 minutes or so from 12 or 17 A-h SLA batteries, or typical 50-100 A-h automotive car starter or deep cycle batteries. But make sure the output to the induction heater is properly fused in case of a magic smoke event. And make sure the device is properly contained in some sort of "blast shield" such as a NEMA electrical box.
                      USA Maryland 21030
                        Recognizing that the necessary batt. charger transformer mods are way above my knowledge level, I ordered a half dozen 750W server power supplies on ebay for a little over $9 each. I watched Mads' great video where he describes in detail how to isolate the cases & boards of the same model HP power supply that I bought & he connects 3 of them in series for a 36V 60A supply. Looks like a great (ahem) bang for the buck!
                        He mentions a 20000uF capacitor bank in series with the output for "load sharing." I found a deal on ebay for a 30000uF/65v cap. Would the larger value be a problem?
                        I kept one of the batt charger bodies and it looks like it should be big enough to mount the PS, the IH unit, the cooling water reservoir/radiator/fans & plus an ammeter & voltmeter. It already has a power cord & wheels to roll it around in the shop!
                          I think that means a capacitor should be connected across the output of each power supply, but I don't see how that will help load sharing. It could also be a single capacitor across the series connected power supplies, but, again, not sure how that will help load sharing. Which of Mads' videos describes this? The individual 12V supplies will always see the same current. A larger capacitor might cause issues with a large surge current at turn-on, so perhaps add a 1 ohm power resistor in series with the output to charge the capacitor at 65 amps, and then a switch or relay across the resistor to bypass it once the capacitor is charged. You might be able to make a simple surge limiter using a 12V relay coil and a 24 volt zener in series that will pull in and bypass the resistor once output on the capacitor reaches about 32 VDC. The following circuit also has an automatic discharge function, which is also a good idea.
                          USA Maryland 21030
                            Thanks Paul, I always appreciate your electronics advice. The 1st mention of a cap is in this video: https://www.youtube.com/watch?v=xRAlXCzsY3Q and this one mentions the value: https://www.youtube.com/watch?v=v-TsBLFp8yo
                            So it could be OK to run these in series without a capacitor? It seems to my definitely un-trained mind that whatever magic a cap provides should already be in there seeing as how these things are made & used by the ba-zillions. I certainly don't know and was trying to emulate Mads who knows his stuff.
                              Using the server power supplies, they already have enough filtering to keep the ripple voltage on their outputs within some limit. They will automatically load-share by virtue of being voltage regulated, and because the current is the same through all of them because their outputs are wired in series. This is unlike the battery charger brute force 60 hz 'old style' models which actually need a high value of capacitance after the rectifiers to keep ripple voltage down to design levels.
                              What would be good is to have some capacitance across the full output voltage, and probably tie that in right at the input to the induction heater module. There should be some kind of input filtering on the module already so it can be stable- I would think so anyway. Perhaps some attention should be paid to this area, just to make sure the module and power supply don't freak out with each other. A huge capacitance added across the power supply would probably freak out the power supply- it will be faced with operating into what will appear to be a dead short. Some will not like this, others will give reduced current until the output voltage is able to rise. In any event the ripple current either from the power supply or reflected back to it by the induction heater load is at a high frequency, and you would need to use a cap meant for switching power supplies in order to make much difference anyway.
                              A thought about the power supplies in series- if any one of them was slow to start relative to the others, it would see an abnormal voltage across it for a time if the load was on when they're powered up. I would make sure that you use a power-up sequence so load is always off before power up or power down. If you use the extra cap at the heating module, the cap stays wired to the module and the load switch is between the input wire and the power supply. The cap could be 50 or 100 uf, or 1000 uf- it's just going to serve to keep noise down on the wiring.
