"Soft" in my case was IIRC, about 30A Durometer, and about 15mm thick x 75mm diameter.
Truning soft rubber/polyurethane
Good idea! That ought to work.
I bet you found out just how much shredded rubber it tossed around, though! Grinding the rubber was bad enough.CNC machines only go through the motions.
