While playing around, measuring my 1-2-3 blocks after stoning them, I decided to lubricate my Mahr Millimess indicator. It is about 40 or more years old and it tends to stick when it is stored. It would work after holding the plunger down for a minute or two but the next time it would stick again. So I opened it up and added just a fraction of a drop of light oil at the jeweled bearings and wiped off the excess. I hope that was the correct thing to do. I will find out tomorrow when I test it after sitting overnight.
But then I noticed my oily fingerprints on the face after I replaced it so I decided to clean it, with alcohol. That was a mistake. Who would have figured that those 1950s or 1960s Germans would have printed the face with ink that would dissolve in alcohol. Well, they did. I did notice that the markings were being cleaned off before any of the scale markings were erased, but some of the text was gone.
So, be warned. If you open up a Mahr Millimess indicator, DO NOT CLEAN THE FACE WITH ALCOHOL. Perhaps this is well known, but I certainly did not know it. I wonder if they still use such a fragile ink. And I wonder if other manufacturers of indicators do anything like this.
