Was just curious how often every one has there Milling Vise on your Mill,just about every pic on here there is a Vise on it.My Vise get used very seldom I find it in way for holding larger peices on the table,95% of time mine is off the table.
How often do you Guys have your Vise on Mill.
If it fits in the vise I use the vise. I'd say that 85% of the stuff I do uses the vise. But I'd have to say that much of my own work revolves around smaller vise friendly items due to the nature of the majority of my projects.Chilliwack BC, Canada
Mini bike would probably be easier if mounted upside down.
I have had an Indian frame and Harley frames on my table.
And bored out a few BobTTach assemblys hanging over the side of table they are around 4 ft long.
33 inch race care slicks deflated on the rims clamped tobthe table..
Sometimes a vise, usually offset a bit so I can still put other work or the rotary table on beside the vise.
Some days you wish you had a second mill.
Originally posted by 754 View PostMini bike would probably be easier if mounted upside down.
Mines on 99% of the time. I only have a small RT so most of the time I can get it next to the vise even with the vise centered on the table.
Even keyways in long shafts or long parts I will use the vise if I can. I just set blocks up on the table high enough to clear the bottom of the vise and set the part on them and use the vise to hold it. Use some machinist jacks if need be.
I would have to say 97.5% of the time,,, vise on one side and the RT on the other, they are almost a permanent fixture that's why I LPS-3 them before anchoring them down cuz sometimes they can be there for a half year at a time maybe more...
that's a substantial amount of time esp. when you use mist coolant, it's enough to cause severe rust if you don't use any protection, all's iv ever had was staining...
