What type of abrasive belts for steel?
  • What type of abrasive belts for steel?
    I have been using the abrasive belts made for wood on my old 6" x 48" Delta floor-mounted belt sander to occasionally work steel and iron. They do the job but soon wear out, plus they pretty much ruin a belt for wood.
    I am wondering if there are better belts made for steel and iron that last a long time. Any thoughts from you guys? And where do you buy them?
    3M cubitron, Norton Blaze or other ceramic belts from other makes. Zirkonia belt if you want mid-range price/performance
      ^^^ yes... good belts cost a lot more but are well worth it.
      Central Ohio, USA
        The blue Zirconia belts are the best value for your money. We run a couple different brands from
        Europe--can't remember the name offhand but they're very good. We've tried the 3M Cubitron stuff
        in sanding discs, grinding wheels and sanding belts and the extra cost is't worth it--they just don't
        last that much longer. And, as far as I'm concerned, you should stay away from Norton. In 40+ years
        of running our shop I never found a Norton product that I liked or that performed as well as the
        European offerings...
        Keith
        __________________________
          Thanks guys! Blue Zirconia belts! I am going to search for them now!
            And if you're going to run the Zirconia belts--which I think is a very wise choice--run 24 or 36 grit if you really want
            to remove some material. Don't mess around with 60 or 80 or 100 grit unless you are truly trying to get a super
            fine finish. A 36 grit belt will soften up pretty quick as the edge wears off the abrasive. We just keep a few of the
            older belts around for those times when we want a finer surface finish...
            Keith
              Defiantly these ones. I have some on a small belt sander in my home shop, I don't remember the brand. There is a tear down the middle of one which hasn't affected its operation in the least. It's been there for many months now and since I'm retired and cheap I haven't changed it. Still going strong. Still cuts very well.
              Southwestern Ontario. Canada
                Where is the best place to get belts from?
                  I’ve found that the 50 grit seems to be a great choice, aggressive enough to cut, but fine enough, where I do not have to change belts to get a good finish. I have been using Carborundum 2” x 48” 50 grit belts on my Jancy RaduisMaster, for about 8+ yrs, at about 4000 fpm, they work great.
                  jack
                    "Run 24 or 36 grit if you really want to remove some material"
                    Thanks for the tip! I looked into the Zirconia belts but haven't ordered yet. Was thinking about 100 grit but will follow your suggestion when I order. I usually buy coarser wood abrasive belts to be able to use the worn down belts for finer work. I should have been thinking this way when I was looking.
                    Ain't this website a great place!
                      When I was still working for an employee, we went through a lot of belts on our belt sander in a toolroom with about 50 people using that sander. We switched to the blue zirconia belts and our usage dropped dramatically. I use them in my shop now too.
                        As far as where to buy... check out Benchmark Abrasives out of Arizona... I bought some 40 grit flapper discs for my 4 1/2" grinder, and some 2" quick locks for my die grinder and both are awesome... The flapper disc last more than double what I was getting out of the dewalt ones...both Blue zirconium...and the 2 inch I got in ceramic... the 4130 chrome molly barely touched it...And I have no affiliation with benchmark other than being a satisfied customer... oh I almost forgot... they are cheaper even with shipping than I can buy locally!
                          I had an ad show up on my facebook page for them. It was for ten or twelve flap disks for the price of shipping. I haven't tried them yet but probably will in the future. Thanks for the review.
                            Some suppliers:
                            https://www.bladeforums.com/threads/...-price.860299/
                            Supergrit and Pops knife supply seem popular accross several forums
                              I like AA Abrasives. Nice quality belts. Omni directional belts have a smoother seam that you may want to consider.
