Except for the doors and the vacuum hose/nozzle that reaches each grinding station the table is done. But the vacuum hose/nozzle is causing me problems.
I'm looking for a flexible 1 1/2" to 2" OD smooth bore hose that stays put where ever I bend it to. My plan is to use one flexible vacuum hose and bend it where necessary to reach each of the 6 grinding stations. So when I adjust it to suck up the grinding dust I want it to stay where I put it.
What kind of hose would that be and what search words would one use to find it? Vacuum hose would work although it's not smooth on the inside but it would work. But the problem is making it stay where I put it. I really don't want a bunch of clamps or brackets hanging all over the place to hold the hose. Probably 20-24 inches of hose will get me to all the stations. The 2" diameter hole in the center of the table is the vacuum source port.
Any Ideas?
Ron
Any Ideas?
Ron
