Losing the suction through small diameters is certainly a factor that needs to be closely examined. I've got a couple of shop vacs which came with the small 1 7/8 hose but with an inlet fitting that would take the 2 1/2" hose too. When fitted with the larger hose the difference in both volume and velocity was like night and day. The increase in air loaded the motor down but it moved so much air and would suck things in from a lot further from the end of the hose. Just what we'd want for a vacuum system on the grinders like this.
Now if the vacuum had a lower power motor going to large on the hose would not maintain the FPM in the hose. And I saw this in writeups on dust collection systems when I was trying to pick the size of ducting for my wood shop collection system. Basically these instructions all said the same thing. Keep the duct or hose as large as you can while still allowing for a fast enough FPM in the duct/hose to stop the particles from settling. And it actually warned against using reduced size diameters at the collection funnels as this would act as a restriction and reduce the FPM in the duct/hose. But at the same time it also stressed the need for smooth inner surfaces.
Bottom line is that for a good shop vac I'm thinking that between 2.5 and 3" is likely the optimum size to get the most volume and still have a good flow rate in the hose. And if using the commonly available stuff I'd certainly go with the 2.5" hose and ensure it stays at 2.5 through the whole collection system from connector funnels to the vac.
