I just bought a Curtis CT55 Two Stage compressor, used, 8 yr old. Like new condition.
I drained the oil before I moved it and now need to fill it. Manual calls for some special FSC-1000 ISO68 Curtis Lube that is no longer available as far as I can tell. What would be a good quality equivalent that I could get locally or order in?
Is there any reason to wire an starter/overload in front of it or just straight to the dedicated 30A breaker in the panel? I don't think the PO had a starter on it, but I didn't get a chance to see the wiring on the other side of the wall.
