Last week I was attempting to move my craftsman radial arm saw out of the garage and into the storage shed. While loading the saw on a small trailer by myself, it got one leg off the ramp and toppled sideways onto the driveway. When I got it standing upright, the blade was 3//4" to the right of the cut line. The angle brackets that the table is attached to were bent, as well as the top of the frame where the main column is attached, causing it to lean several degrees.
The next 2 afternoons were spent tearing the saw apart and getting it back in alignment. I'll save you the trouble: "Clumsy Bastard"
