I normally use an endmill holder for endmills with weldon shank but for others I use a collet. With the Weldon shank, the depth with which the endmill is inserted is automatically adjusted by the flat spot, however when the endmill is held by the collet there's more flexibility. So, the question is, when the endmill is held by a collet can you insert it deeper to get more rigidity, or should the entire fluted portion of the endmill always be exposed (will that damaged the collet?) ? As always, thanks for your many good advices.
Albert
Albert
