A Blast from the Past--Radial Engine
  • A Blast from the Past--Radial Engine
    I had lost my 3D cad files of the Webster engine due to a computer crash, so last night I went thru about 100 old CD Roms hoping I had saved it to a disc. I never found it, but I did find a disc with all of the files to a radial engine I had built about 10 years ago. This is an amazing little engine which runs on compressed air, and is fun to build and to run. I am attaching a picture of the cad file I found last night, and a free download link to the drawings.--Have fun.---Brian
    http://www.mediafire.com/file/uzhvza...ngine.zip/file
    That's a really nice looking engine. I've downloaded your file and looked at a few of the pages already.
    Just wondering from looking at the 3D and the first couple of drawings. For added giggles would it take a lot of work to convert it to a rotary setup?
    I'm thinking the crank gets fixed to the vertical post of the stand. The cylinders with the star plate would become their own flywheel. You've already got the air flowing up through the star plate. So it would only require that the plate be a bit thicker or use a pressed in longer bearing boss for added support and to hold a couple of seals. Might make for an interesting variant?
    Chilliwack BC, Canada
      Brian, that is cool.
      How did you know I was about to ask you about radials??
      You have built so many engines I was about to ask you about this:
      http://www.agelessengines.com/
        Ringo--the engines in that link you posted are far more complex than the little radial I built.---Brian
          BCRider--If you think you can do it, then by all means do. It was over ten years ago that I built that, and without setting my head on fire I don't know if what you are suggesting is possible or not.
            A video of the engine running---
            https://www.youtube.com/watch?v=dib1JCKUmAc
              Brian,
              Have you ever considered building a turbine engine? I am just fascinated with them.
              Another Brian
                Before the war, the Bristol aero company made some 3 cylinder radials, they do look weird.
                  Turbo engines don't interest me much. I like old school industrial revolution stuff.
                    I love the bubble machine ! ! It must be a real hit if you're demoing any of your "steam" engines outside.
                    I'm shamed to admit that I've yet to build any sort of engine. But I'm keen to start if I can clear up any number of other things. I think I need a warmup. And making ONE cylinder of this engine to start with and learn the "tricks" would be a good start. Then the radial or rotary.... or maybe both sitting on the same board..... OK, now I'm leaping ahead again.
                      BCRider--I like your posts. I'll tell you a dirty little secret. The first engine I ever built was a single cylinder wobbler, designed by a famous model steam engine builder Elmer Verburg. I built it and it worked so well that I used his cylinder, piston, and valve hole positions to be the basis for this radial.
                        My kind of thinking... Luv it...
                          I was admiring some radial engines when I visited the Wright Patterson museum in Dayton OH.
                          They had some that were cut away so you could see the internals.
                          JL....
                            Wanna figger how a radial works??
                            Here you go.
                            They are weird at first with the cam moving 1/8 crank speed, the odd number of cylinders, the firing order, the master rod, reciprocating rods, and all that.
                            This guy did a masterful work on the radial:
                            https://www.youtube.com/watch?v=qjnQKXNPsk4
                              Some of the radial engines were designed where the crank shaft was stationary and bolted to the fuselage. The cylinders rotated around it. I can only imaging how much work had to go into balancing the cylinders and related parts. Not sure what the advantage was.
                              JL............
