Finished VFD mod to my lathe
  • Finished VFD mod to my lathe
    Sent from my SM-G950U1 using Tapatalk
    Cool.
    What functions did you assign to the stock buttons?
    Len
      I hope you are going to cover the resistor and terminations?
      Expanded metal works good for that.
      Jon
        Originally posted by QSIMDO View Post
        Cool.
        The jog button is set to forward 5hz, the E-stop to E-stop with 0.5 second Decel. Accel to 3 seconds, Decel to 2 seconds.
        Turned off Decel stall protection so it uses the external resistor.
        Where the flood coolant switch would go is the Pot for speed, 0hz to 120hz.
        The Apron mounted control lever is wired for Forward/Stop, Reverse/Stop operation.
        Used a Cat5 Ethernet cable for signals to VFD, used all 8 wires.
        Future additions, maybe a toggle switch to switch between maybe 3 second Decel and 1 second Decel for threading. Possibly another switch to turn flood coolant on and off.
          Jon
          I should, doesn't even get warm doing a few E-stops. Think possible high voltage/current would be the bigger concern.
            Touching those will light you up big time. A perforated metal shield with a swarf cap is in order.
            Swarf shorting the resistor will take out your VFD braking system.
            Check your deceleration time setting with a heavy chuck, decent sized work-piece, and from high speed. It might not be able to handle that, braking resistor or not.
            lakeside53
              Well, definitely have to address all of that. Of course I have to go back to work again...
                This is just an observation that might not apply. Feel free to ignore.
                I noticed that the resistor is mounted by way of caps on both ends. I thought that one of the cooling mechanisms for a wire wound resistor is the air moving (via convection) through the middle of the tube. It seems that the end caps will interfere with that.
                Dan
                  Holy cats! That will take care of any cats. Of course you won't need them because it will probably eventually get the mice too. I guess that assumes they are using the lathe.
                  Is it possible for swarf to bounce down there, and into the motor fan?
                  Btw, nice work.
                  Originally posted by RB211 View Post
                  Glug
                    Swarf will get everywhere but the rear splash guard protects the motor pretty well. The cooling fan on the top of the cabinet is guarded and filtered.
                    I'm wondering how high the voltage gets on that resistor, maybe 300v. It's only active for three seconds or less at a time.
                    The kind of work I do is never on anything massive, but you know how that goes. This week I had a job that exceeded my Bridgeport's Z height... Maybe in two weeks I'll be turning something that weighs 300 lbs at 2000 rpm and have to hit the E-stop... Probably melt the wires.(which are high quality USA made)
                      You know you can buy terminals blocks that fit on the DIN rail? Avoid use wire nuts all together.
                      https://www.digikey.com/products/en/...9?k=din%20rail
                      https://www.alliedelec.com/product/e...E&gclsrc=aw.ds
                        If you look closely, you'll notice that I used quite a few DIN terminal blocks in both cabinets. The bottom cabinet could use some for the grounding wires. The left most cable was too short to feed it directly into terminal blocks, hence why there's wire nuts at the top. Not ideal, could just run all new wires like I did with the front panel, might just do that.
                          Depends if the active device is sinking or sourcing. If sinking (i.e. the "switch" is to the common) the full dc voltage is present whether braking or not.
                            Just piling on, I know, but the terminals of the resistor are normally hot with the bus voltage. You want that covered up.
                            The resistor ventilation thru the center will not be an issue in stop duty. the resistor is commonly mounted just as you have done. Plus, there is a duty cycle setting in the VFD, which is normally co-ordinated with the resistor wattage according to a formula that the instructions ought to have.
                            The braking resistors are often overloaded by factors up to 10 or more. it is the duty cycle that determines heating. A 250 watt resistor, if made for the purpose, can take 2500 watts 10% of the time and that equals 250 watts average. The only caveat is that the 10% cannot exceed the "integration time" that the mass of the resistor provides. So on time 5 seconds out of 50 is likely to be OK, where 5 minutes out of 50 would not, because the resistor would cook in 5 min on time, where it would not in 5 seconds on time. But stopping a lathe etc does not take 5 minutes, and usually not 5 sec even.
                            You do need a resistor of a type made to take excess current. Not every one of them is.
                            2730
                            Birds are NOT real, they are spying on you
                              The first photo looks just like my lathe, which is the Prince 13x40 from Jessey in Taiwan. Is yours the same? How do you like it?
