Spin Fixture for the Surface Grinder
  • Spin Fixture for the Surface Grinder
    This weekends project, a little spin fixture for OD grinding. I wanted to see if I could make a spindle. It uses 6203-2RS bearings with a spring to preload the balls and minimise runout. The body is a cast iron piston rod end or something.
    Some pictures
    Drew it in solidworks
    Turned a 4" disk from 1/2" plate
    Indicated off the reference bore I made with the intention to matching my 4" rotab from Little Machine Shop
    Welded in the spindle I made
    Sent from my SM-G930W8 using Tapatalk
    Cut down the cast iron and bore the bearing holes. I machined some flats referenced against the bearing bores and assembled the unit after I faced off the faceplate to correct the alignment errors after welding.
    I clamped the faceplate to an angle block and ground the cast iron flat, made a bottom plate and ground that too.
    Tested it out on a old tool steel shank and it works nicely.
      It needs some finishing touches. One thing i want to do is case harden the base, and make a V block work holder that many higher end units have. I also need to futz with my hackjob ER32 holder I made last year as it has quite a bit of runout, making it close to useless.
        That's some nice work there.
        JL....
          Hire out your welding.
          -D
          DZER
            Cool little fixture.
              Someday I will have you ...…………..
              Someday.
                My brother gave me one of them , it says electrode former, looks the same.
                  Someday.
                  I've spent countless hours spinning the handle of one of those. I want one with a motor . I made a tapered plug that fits into the handle, with a 1/4" hex flex shaft on the other end. I can now use my small 12v hex driver to spin it which makes pin grinding so much nicer. But it's not the same as having one on a base plate with a motor attached.
                  Nice work Matt, looks like a pretty useful setup you have there.
                    -D
                    Thanks Doozer.
                    My flux core welder is a $130 unit that isn't rated for beyond 1/8" and preheating makes the spatter fuse extra hard to everywhere I don't want it, so I just gave it a few squirts and crossed my fingers. Doesn't have to withstand much force, especially in the axial direction so I don't think it will break.
                    I was thinking about how to do a limit-setting feature so I can grind a radius without fear of overshooting, but I didn't come up with something that wasn't way over complicated.
                      Did some tweaks on my ER32 collet holder and now it is running a lot nicer, I frankly don't know what was going on in my head when I made it as there was like .01" face runout when mounted on a dowel pin in the 4 jaw. Did a similar process to get it tuned in around .001" on the spin fixture so its going to live there for the time being.
                      Sent from my SM-G960W using Tapatalk
                        Nice work.
                        Added to my list
                          Originally posted by mattthegamer463 View Post
                          Thanks Doozer.
                          Just could have made it a .003" press fit and forget the welding.
                          -D
                          DZER
                            -D
                            If it don't fit in my bench vise, it don't get pressed
                              -D
                              .003 would be a lot of press for a shaft that size.
