Why is this switch hard to find?
  • Why is this switch hard to find?
    Stupid question, but I don't know the exact phrasing to use to find this type of switch. I want it to disconnect the power in to the VFD box on my lathe, just as this person is doing on his conversion.
    Sent from my SM-G950U1 using Tapatalk
    Selector Switch
    https://www.alliedelec.com/switches/selector-switches/
      When you get into industrial switches, it is common to buy the electric end and the knob/bezel/mount separately. You can mix & match a great variety of compatible hardware. The Allied link above shows a few, DigiKey and Mouser have large selections as well.
        Rotary on-off switch.
          Yes, a double pole single throw switch function, rated for the current, and probably about like PSTP's illustration. The "cam" witches are the ones I prefer, but any switch type UL rated for the power level and voltage will work.
          A switch with the "1" and "0" designation should disconnect BOTH lines in the "0" position, so get a double pole switch if you want to keep that bezel.
            Exactly. Allen-Bradley, Telemecanique, etc.
              Mcmaster Carr has them
              https://www.mcmaster.com/electrical-controls
                Originally posted by portlandRon View Post
                Ordered it. Yes, needed one that could switch 25 amps. Thank you
