Need VFD advise
  • Need VFD advise
    While using the mill for the first time, it became evident that a reversing switch is sorely needed. Since a decent one is priced only slightly less than the VFD below, my thinking is that I should install the original 3 phase motor and go with the VFD. Since I don't know squat about a VFD, my questions are, will the VFD provide a reverse rotation function, and is it powerful enough to handle the 2 HP motor? Also will there be a downside to doing this, or should I stick with the 1PH motor and get a reversing switch? Any help will be appreciated.
    Dave C
    VFD: https://www.ebay.com/itm/3-0KW-220V-...D/202694510173
    Lewis Grizzard
    Read this article that I wrote on the subject. All your questions answered.
    http://www.oursplitrock.com/mill-4.pdf
    And yes, 3 phase and a VFD IS the way to go, the only way!!
    Peter
    Grantham, New Hampshire
      Short story:
      VFDs provide reverse, yes.
      THAT VFD is spec'd for enough HP to more than power a 2 HP motor. (but see below)
      The only downside is if the mill has multiple belt positions for speed selection, but that you decide to try to cover all speeds with the VFD as "the" speed control. You usually are better off keeping the pulley system, and back gear type speed range changer (if any). The VFD cannot give you the power needed to swing big cutters at low speed if you try to get that speed by turning down the VFD speed control. Large cutters may just stall the motor if you try to do that.
      Details about "that" VFD..... It looks a lot like the infamous "Huanyang" VFDs, which have been all over the place on reliability and even performance. Some folks never have a problem, some have had problems right out of the box, or within a pretty short time. I would suggest that the low cost may be telling you something. A TECO or Hitachi VFD will be a much better bet as far as being a good reliable unit.
      Your mileage may vary, some settlement may occur, etc, etc.
        Just about all VFD's have a PLC on them, i.e. low voltage I/O for control and status output/control.
        One feature is if you are in FWD run at high rpm and switch to the REV while doing so, the motor will decelerate at the programmed rate, before accelerating up to REV.
        Max.
          I like Automation Direct. Not the cheapest, but good support in USA, reliable units, easy to program. The remote control costs less than $20 to build and lets you put the controls where you want to. On my table saw the remote control is on a magnet and a 10 foot cable. Allows me to get long boards in position before I start the saw and when I want to cut short things,it sits right under my left hand read yo hit the kill switch.
          Peter
            Automation Direct also sell WEG, which are a excellent line I have worked with.
            BTW to the OP ensure you get a Vector capable control not Voltage/frequency version for your application.
            Max.
              Max.
              Max, does the line "Torque Control:Torque increase settable by max. 10.0%. The starting torque can reach 150% at 1.0Hz." indicate vector control?
              Dan
                Dan
                Not Max, but..... That may indicate the availability of a low speed boost feature that is not vector. It is really just a modification of the V/Hz "law" at low speed, giving more V than the normal V/Hz would call for. It tends to give a better very low speed response, but is not a cure for the problem of low torque compared to a mechanical reduction. (For that matter, vector control does not do so much for that issue either)
                The feature is reasonably common on VFDs intended for the HVAC market. (You likely do not want an HVAC type, they often lack many settings which are available on general purpose VFDs)
                  Dave C
                  i have to commend their ingenuity.. putting holes through the heat sink to cool off the capacitors
                    Dan
                    Yes typically starting torque can be 150% - 200% of rated torque at close to zero Hz.
                    https://www.machinedesign.com/motors...ol-method-vfds
                    Max.
                      Go by current rating, not HP rating. A 3hp VFD is 2.2kw, 10.6 amps.
                      One complaint about my Teco CV7300 that I blew up, the jog function will not work if it's not in run. The new VFD I have that is billed as the TECO CV7300 replacement calls the jog function jog/run. Works as I would like.
                      Try to get a Vector drive VFD. Gives you more torque at lower speeds. Still want the backgear though in case you want to use a 5" holesaw on something.
                      Sent from my SM-G950U1 using Tapatalk
                        Thanks all for your help. My questions have been answered, and it appears that I need to look elsewhere for a more reliable unit. I did like the price though
                        Lewis Grizzard
                          Read the manuals to the ones you look at. Expect to pay 200 to 350 for a decent one.
                            There is one now on E**Y that is just what you are looking for.
                            https://www.ebay.com/itm/Automation-...IAAOSwMoldCrJU
                              thanks, but I'm not too keen on buying a used one.
                              Lewis Grizzard
