Spade drill holder
  • Spade drill holder
    I just got gifted some spade drill tips. I would like to machine my own holders. I got a close up photo of one off of Goggle. My question is has anyone machined up their own spade drill holders?
    Sent from my iPad using Tapatalk
    There are many different styles of tips. It depends which ones you have.
      If you subscribe to the Magazine, there was an article about making the holder for whatever style the author had. Prolly a couple years ago now.
      Oregon, USA
        If they are 1/4" hex, take $ 10 to HD, get a Irwin 12" extension with a quick release clutch. I had to drill 20 ea. 1 1/2 holes 6" deep in cherry, no problems except for a sore wrist.
          I think he is talking about metal spade drills, which are a lot different than wood spade drills.
            One of these: https://www.ebay.com/itm/Waukesha-Sp...ox!08817!US!-1
            not one of these: https://www.ebay.com/itm/Bosch-DSB10...a6855134a3dc4f
              Yes the metal kind like in the upper. Mine has a notch and one hole
                I’ve subscribed for several years, but don’t remember the article. Can you reference it. I’m assuming your speaking of Home Shop Machinist
                  Not sure if this is the article that you are thinking of, but a quick search of the article index found this:
                  Spade Drill Holder Don Wiederhold Shop Accessories HSM Vol. 34 No. 1 Jan-Feb 2015 24
                  I don't know if I have that particular issue so I could not look to see the details, but it sounds like what you are after.
                    The following link shows how a spade drill bit holder might be constructed:
                    The patent may give you some ideas:
                    A spade drill is provided with a holder for a spade cutting blade which is clamped in a slot of the holder by means of a clamp screw. The spade cutting blade is essentially formed with a cutting surface coming to a central point and of the same shape as the first cutting surface with an abutment surface located within the spade drill holder in the clamping slot which receives the cutting surface for holding the bit in place with means in the form of a clamp located across the clamping slot to grip the spade drill bit.
                    USA Maryland 21030
                      Thanks to both of you. I appreciate it.
                        Now I need to go digging through my stuff to see if I have that issue here someplace.
                        Looking forward to see what you come up with!
                          I’ll look to see if I have that issue, it may be one I let a friend have. My plan is to use rage blade, the photo and work out the first holder. Even used holders on EBay is expensive.
                            I just looked at my copy, it is Jan/Feb 2015. The article shows a holder for 130 degree spades. I don't know if flat bottom spades work with the same holder or not.
                            Oregon, USA
                              All of the big names such as Sandvik and Kennametal produce this type of drill system, but there is no standardisation you could rely on.
