A 4 inch cube- a modern brushless rc motor of that volume can be capable of more than 10 hp. Because of that, it can be run at a fairly slow speed and still have lots of torque, even though the continuous power would be down to 1 horse or so. If you figure out the voltage required to run at say 300 rpm, then factor in the continuous current it can take without overheating- this could be the motor that would drive your lathe to any speed you'd want with only one initial speed reduction stage. Make this a belt drive to the spindle, with a ratio of about 2.4 to 1. Since typical motors like this are rated at around 6500 rpm, you can easily get a spindle speed of 2000 rpm, and you can go down to perhaps 75 rpm and still get more than 1/2 horse out. In fact, because you wouldn't normally need much power at high rpms, you'd want a control that would alter the current limit with rpm. It would have a maximum current (not interrupt-able) and would automatically lower that setting as the motor rpm increases. That way you neither need nor want to supply more than a certain amount of power to the motor. No need to have 8 kilowatts of available power to satisfy the motors maximum thirst- something around 1200 watts would give a fairly impressive performance.
This is a good concept I think. The right power supply and controller would be key- and of course none of this is going to be cheap.
