When you weld or braze a steel part which was hardened, isn't it likely that the heat will anneal it? To get around this, are parts welded first and then heat treated? This wouldn't be possible for brazing since the curie point would be higher than the melting temperature of the brazing rod. Is brazing simply not compatible with heat treating?
Is is possible to braze HSS to normal steel similar to the way carbide is brazed? If I remember correctly, I think this is what bi-metal is, but how is this done so that HSS does not lose hardness?
Albert
Albert
