There was a local fellow that was a fighter pilot in WW 2,he was quite a character.After spending a afternoon in the Bar with a bunch freinds,one fellow was ribbing him about his flying abilities.The guy said if your that good of pilot why don't you fly threw between the grain elevators.A measuring tape and crowd gathered at the two grain elevators that were 80' high and the space between came in at 12" wider than the pilots private plane,he stated that's lot of room.He got in his plane and flew between as fast as it would go about 20' off the ground.The spectators said it was like the plane was on some kind of guidance system as numerous ones said he was dead center and the wings were horizontal.This was a long time ago but the pilot had a lot of talent considering having a belly full of booze.
OT: Sad day in aviation: Collings B17 has crashed
Originally posted by Tundra Twin Track View PostThere was a local fellow that was a fighter pilot in WW 2,he was quite a character.After spending a afternoon in the Bar with a bunch freinds,one fellow was ribbing him about his flying abilities.The guy said if your that good of pilot why don't you fly threw between the grain elevators.A measuring tape and crowd gathered at the two grain elevators that were 80' high and the space between came in at 12" wider than the pilots private plane,he stated that's lot of room.He got in his plane and flew between as fast as it would go about 20' off the ground.The spectators said it was like the plane was on some kind of guidance system as numerous ones said he was dead center and the wings were horizontal.This was a long time ago but the pilot had a lot of talent considering having a belly full of booze.
I'm just here for the paycheck!!
Since we're telling "war stories" here one from a buddy that worked for a now long gone local hop outfit.
The outfit flew out of the harbor so obviously lots of float planes. But one day they got a deal on an older Grumman Goose I think it was. Amphib either way. One of the higher up's picked it up from the airport and took off from the runway. It was a short hop from the airport to the harbor. In that time he forgot to retract the wheels. He's on final for a water landing when his local guy on the docks panic radios him that his wheels are down and to abort. So up he goes and flicks the switch. But now he's so flustered that he decides to hop back to the airport and touch down there. Yep, forgot that he had flipped up the gear or didn't trust the switch and didn't bother to look out and see what was what. Tore up the belly fairly badly when he scraped in to a halt.Chilliwack BC, Canada
here a link to the NTSB preliminary report:
Originally posted by Ringo View Post
Only a guess but with one or two engines out and no flaps deployed, a stall near ground level and perhaps dipping a wing in the process seems reasonable. I will be interested to hear what RB211 has to say. The report seems to confirm that fuel was not at issue.
Sparky, the engines had just been rebuilt prior to the last anual inspection in Jan.
Review of maintenance records revealed that the airplane's most recent annual
inspection was completed on January 16, 2019. At that time, the airframe had accumulated
about 11,120 total hours of operation. Engine Nos. 1, 2, and 3 had 0 hours since major overhaul
at that time.At the end of the project, there is a profound difference between spare parts and left over parts.
Originally posted by Sparky_NY View PostWhat I found interesting was that 3 of the engines had zero hours since major overhaul. If I am not mistaken, right after overhaul is the most likely time for a engine to fail. Also interesting was that the flaps were determined in the retracted position, not good for a slow landing approach.
flaps are drag, and with engine out you want least drag
the most glaring point in the whole report is that says right downwind approach,
a right side approach turns him into the bad engine side, that is weird to me
(reactivating old thread)
Citing a poor safety culture, the FAA prohibits the Collings Foundation from carrying passengers:
https://www.courant.com/news/connect...jyi-story.html
From the article:
"An inspection of the bomber’s engines found problems significant enough to cause the FAA to question “whether the engines were inspected adequately and in accordance with the applicable maintenance requirements.”
Specifically, the inspection found that magneto and ignition failures existed in the aircraft’s No. 4 engine. Magnetos, engine-driven electrical generators that produce voltage to fire the engine’s spark plugs, were not functioning properly. An attempt to jury rig one had left it inoperative, according to the report. A second magneto on the No. 4 engine, when tested, produced a weak or no spark to four of the nine cylinders it was supposed to fire."
"Inspectors also found that all spark plugs required cleaning and that all of the electrode gaps were out of tolerance. Further engine inspection “indicated signs of detonation and associated damage," the decision reads."
"An inspection of the No. 3 engine showed “all spark plug electrode gaps were out of tolerance, fouled, and revealed various signs of detonation." Inspection of the engine also revealed problems with the cylinders, according to the report."
The FAA report can be read here:
https://www.scribd.com/document/4533...ion#from_embed
The final NTSB report on the accident is not yet complete.
From the article:
I can't let my wife read this. She'll never let me take a ride for charity at an air show again.
From a previous post: Engine Nos. 1, 2, and 3 had 0 hours since major overhaul shortly before the crash. What kind of overhaul does not include spark plug maintenance?
DanAt the end of the project, there is a profound difference between spare parts and left over parts.
Originally posted by danlb View PostI can't let my wife read this. She'll never let me take a ride for charity at an air show again.
Dan
Dan
