This video of NTSB initial information states that the NTSB has at least portions of both wings, all engines, the tail, and other pieces. That suggests that they have good fuel samples. Even burnt fuel samples would be able to be analyzed to determine if the signature is consistent with the appropriate fuel, or if other material was present.
I noted in your link that there were unburnt pieces, including a tire on its mounting with a portion of the landing gear, etc. The engine in the hut appeared not to be badly fire-damaged, as the data plate was present and readable without soot, etc.
There apears to be enough material to do a good investigation with little guesswork. The aircraft would not have been loaded with much fuel. They carried enough for a many hour flight when in service, carrying a payload and about 10 persons. The fuel carried for these flights would not have approached that.
https://www.youtube.com/watch?v=19vJ27Q5WSg
