I'm in need of an oil seal for a rock cutting machine. Oil is a mineral oil about 30 wt.
Shaft is 1" O.D. but it comes through the wall of 1/8" "box", through a hole already 3" diameter.
Prefer a seal that is mounted in a sheet metal housing, that can be either bolted or screwed to the 1/8" thick box side.
There is about an inch clearance inside as well as outside of this 1/8" box wall.
Otherwise I can make a mounting for it and set a conventional seal in that.
Any suggestions on make and model of seal would be appreciated.
