Have you considered moving the center of gravity on your "bridgy" to the center of the base, instead of using the shaper attachment hole? Extend the 4 bolts, add a plate, with center pin and attach your bridgy crane.
Just a idea I used since I had a shaping head sitting in that spot.
David from jax
David from jax
