I remember learning/reading that if you take a bundle of toothpicks it's actually stronger than a single wooden piece of the same size. Is this true? Does this hold true for steel? Does it actually increase the load bearing capacity (tensile)? I don't quite see this, so perhaps someone can explain.
Albert
Albert
