I have a surplus stepper motor who's shaft I need to turn. The shaft is 1/2" and I need it to be 3/8". How do you do this without damaging the motor.
I was thinking of using the milling machine with the motor clamped down and using the boring head with the cutting edge facing in, but how you hold the shaft so that it doesn't spin?
The other idea was to actually run the motor while it's held in the lathe chuck and use Dremel with a grinding stone mounted in the toolpost to grind it down.
Your ideas would certainly make my weekend productive. Thanks.
Albert
Albert
