I have been brazing small steel parts using brazing flux sold by Lincoln Electric (white powder, I think it's borax) and using plain old brass wire. It works very well and I like the fact that I can use different gauge wire for different jobs. Is this essentially same as the rod that you buy which has thick white flux coated on it?
Also, when do you use the brass rod v.s. the silver solder which I believe commonly has blue colored flux. I like using the brass rod because it doesn't flare up like the silver solder flux.
Albert
Albert
